Hi Hung Dinh,
New version of 1.1.2 JAT3 plugin works properly. I am very happy. But I found one error in writing an item into the menu. If the module is connected to the separator poorly recorded in the database entry.
Write example:
mega_subcontent = mod
mega_subcontent_mod_modules = 16
and should be properly
mega_subcontent-mod-modules = 16
One more thing I noticed. On some hostings T3 has a problem with writing to the cache. Insufficient rights for registration. I can not fix it, so it works without cache. Only turn off the ftp layer, then as well.
Once again, thank you for the excellent work, good luck
Trebor
