November 5, 2015 at 11:31 pm #721625
Hi, how are you?
You are using the JA Jason template, the Ja_Jason – Home Style 5, the “Green” version.
The Bloc is made with K2.
I have a problem with displaying columns.
I’ve looked at this forum, and I’ve seen similar issues, but the solution (add code in k2.css line, float: left) do not work for me.
I want the blog entries to left and sidebar-2 column look, but only shows me 1 column with items, but the sidebar-2 does not appear ..
I’ve seen that if I use the Default Template instead of home-5 appears the sidebar-2. But I need to use the home-5 design issues.
How I can make it appear in the right column K2 in home-5?Saguaros ModeratorSaguaros
November 6, 2015 at 6:35 am #721715Hi Josep,
By default, the JA Jason – Home Style 5 loads ‘mainbody-home’ block, you can see it via file: /root/templates/ja_jason/tpls/home-5.php
<body class="ja-home-5"><div class="t3-wrapper"> <!-- Need this wrapper for off-canvas menu. Remove if you don't use of-canvas -->
<?php $this->loadBlock('header-5') ?>
<?php $this->loadBlock('mainbody-home') ?>
<?php $this->loadBlock('section-home') ?>
<?php $this->loadBlock('footer') ?>
</div>
</body>
However, this ‘mainbody-home’ doesn’t contain any sidebar, you will need to load ‘mainbody’ block instead:
<?php $this->loadBlock('mainbody') ?>
</div>
</body>
Once done, check the back-end settings of module you want to show in sidebar position and make sure that it’s assigned to correct menu item page.
It will show fine then.
November 6, 2015 at 6:35 am #753873Hi Josep,
</div>
</body>
</div>
</body>
This topic contains 3 replies, has 2 voices, and was last updated by Saguaros 9 years, 1 month ago.
