librandi Friend
librandi
- February 2012
- 2 times in 2 posts
June 19, 2017 at 1:28 pm #1042812hello,
I istall the quick start but I can’t istal language and upgrade the joomla version.Can you help me?
June 20, 2017 at 2:37 am #1042900Hi
The language is installed by core Joomla language installer, As u can see the language are showing on site but it’s not installing from Joomla servers. I suggest you to install the language package from Here
And you can also report this issue on Joomla forum.Regards
librandi Friendlibrandi
- February 2012
June 20, 2017 at 5:59 am #1042925thank you,
I try but I have the errors of screenshot-
June 20, 2017 at 6:51 am #1042936Hi
Kindly check the permission of files and folders on site, Also your site is forbidden for me.
Here: http://prntscr.com/flvh5gRegards
- February 2012
June 20, 2017 at 7:25 am #1042949Pankaj Sharma ModeratorPankaj Sharma
June 20, 2017 at 7:55 am #1042960Hi again,
http://prntscr.com/flw31t
it will fix the installation issue.Regards
- February 2012
June 20, 2017 at 2:25 pm #1043039Pankaj Sharma ModeratorPankaj Sharma
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 7 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 6 months ago.
problem to istal language
