devlavoro Friend
devlavoro
- May 2015
- 2 times in 1 posts
August 28, 2015 at 8:48 am #680448Ok, now you’re SU
devlavoro Frienddevlavoro
- May 2015
August 28, 2015 at 8:48 am #746902Ok, now you’re SU
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
- October 2014
- May 2015
August 28, 2015 at 10:50 am #680460Thanks! Now JA Extentions Manager component starts, now i’m trying to update the template but the system respond with an error: “Response from JoomlArt Updater Service: Wrong username and password. Login failed! Please try again
Upgrade failure”
Maybe i’ve to configure the component with my joomart credentials?devlavoro Frienddevlavoro
- May 2015
August 28, 2015 at 10:50 am #746914Thanks! Now JA Extentions Manager component starts, now i’m trying to update the template but the system respond with an error: “Response from JoomlArt Updater Service: Wrong username and password. Login failed! Please try again
Upgrade failure”
- May 2015
August 28, 2015 at 10:56 am #680463OK, updated.
Thanks a lot
Robertodevlavoro Frienddevlavoro
- May 2015
August 28, 2015 at 10:56 am #746917OK, updated.
Thanks a lot
Robertojooservices Friendjooservices
- October 2014
August 28, 2015 at 11:09 am #680543Hi there
So, you have solved your issue ?Thank you,
Viet Vujooservices Friendjooservices
- October 2014
August 28, 2015 at 11:09 am #746918Hi there
Viet Vu -
This topic contains 25 replies, has 2 voices, and was last updated by jooservices 9 years, 3 months ago.
