August 3, 2011 at 2:42 pm #167015
Hi, I’m trying to do mod_janewspro with k2 configuration, but it simple doesn’t work, you may see it at:
http://ja-teline-iv1312373738799.joomweb.com/index.php
Are there some configuration trick to do?
Thanks in advance,
Best regards,
Luis
August 3, 2011 at 6:57 pm #404390Steps:
1- Create new teline iv from page
2- Go to “JA News – Default Layout” at “module manager”
3- change to K2 articlesDoesn’t work for k2. Even if I select all categories.
May am I loosing some configuration step?
Thanks in advance,
Best regards,
Luis
fdr77 Friendfdr77
- April 2011
- 3 times in 1 posts
August 4, 2011 at 11:23 pm #404558about me work fine
August 5, 2011 at 12:52 pm #404663
Hi fdr77,
Setting this options works fine, but the problem is that I can’t see anything at frontpage.
Thanks!
Luis
Sherlock FriendSherlock
- 2478 times in 2162 posts
August 8, 2011 at 10:24 am #404915<em>@aguirrel 257771 wrote:</em><blockquote>Hi fdr77,
Thanks!
Luis</blockquote>
hi Luis,
you can provide me your admin account, the ftp Info into the ticket of MON-217-92356, I will have a checking on this problem for you.
Viewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 3 voices, and was last updated by Sherlock 13 years, 4 months ago.
