  • edna bonfim Friend
    #987777
    I tried to change the positions in "Layout – Responsible layout" -"large" the positions 5,6 and 7. I thought it would look fine, but are different from the original configuration. Also when I see the site in the mobile it’s not work well and the main menu follow unconfigured.
    I would like to know if is possible to reset all and to return to the standard layout configuration?
    1. Doc1.pdf
    Ninja Lead Moderator
    #988048
    Have you configured out it? I see it’s working as well on your site: http://prntscr.com/d9usuj
    edna bonfim Friend
    #988245
    I think I have managed to solve everything..in the moment :-)))
    Thank you
This topic contains 3 replies, has 2 voices, and was last updated by  edna bonfim 8 years, 1 month ago.
The topic ‘Problem view home’ is closed to new replies.
