  • yoshscem Friend
    #180616
    Just installed Puresite using Quickstart pkge on local xampp server (xampp 1.8.0) and i’m getting only errors.
    Enclosed are 2 txt-files reading errors for site view and back-end view.
    Could you tell me where I mistaked ?
    Yosh
    Ninja Lead Moderator
    #466796
    Thanks for your contacting to us, the error is strict standard error with php latest version.
    + About the error with JA Extennsion, you can upgrade latest version from JA Extension Manager on Admin area.
    + And other or special K2 component, I see it is not yet fixed about that
    Other cases, you can disable the strict standards from hosting
    <blockquote>xampp/php/php.ini</blockquote>
    error_reporting = E_ALL & ~ E_STRICT
    Restart Wampp server again
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 12 years, 3 months ago.
