November 7, 2011 at 4:27 am #170455
When i try to send a comment, it takes long time. Also loading notice is not Disappear.
I saw some post at this forum but, i did not see real solutions.
I am working at localhost, so i can not give any information about my site.You said, this problem about e-mail return problem. I am sending e-mail normal way.
Could you say the solution here. Ajax notice does not disappear.I am waiting.
Best wishes.
Blaine FriendBlaine
- August 2007
- 177 times in 154 posts
November 12, 2011 at 5:34 am #424333Hi bilisimlive!
Maybe your internet connection caused the problem. have you checked on other machines?
Let me know the results after you check the load time from another machine and also be sure you are using the most up to date extensions and templates as well!
thanks!November 19, 2011 at 12:17 am #425348Hello, yes i checked the other machines. I am using Joomla 1.7 but i have the same problem. If i disable the e-mail notifications, it is sending normally. But if i enable e-mail nodifications it is giving error always.
What is the problem ?
November 19, 2011 at 1:48 pm #425406I sent a detailed ticket, please check it. I am waiting.
Thank You.
Blaine FriendBlaine
- August 2007
November 27, 2011 at 6:04 am #426655Hi!
Just checking in to be sure someone has gotten to your ticket. please advise.
thanks!AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by Blaine 13 years, 1 month ago.
Problem when sending comment.
