  • alaa_alnahal Friend
    #177941
    I made a module which comtain only an image (993px 300px) to show it under menu on the top of the page, to show it in “slideshow” position , and assigned it to specefied menu .
    but whin I change the landuage to arabic with RTL direction I found that the image has been shifted to the left about 7px
    but in the english language with LTR direction it worked well.
    please I want to correct it in the RTL layout without affecting on its position on LTR direction .
    please try to help me soon
    1. error002
    #456752
    Hi alaa,
    I checked your homepage in firefox and did not see the problem, let me know if it got solved, if it not please give me exactly the url where the issue is being seen 🙂
    alaa_alnahal Friend
    #456817
    thank you for reply
    Change to arabic language in the module in the top page
    or follow this link
    http://www.safainvest.com/index.php?option=com_k2&view=item&layout=item&id=44&Itemid=75&lang=ar
    #456914
    hi alaa_alnahal,
    you open the file of templates/ja_tiris/css/template.css look for this css
    #ja-slideshow .main-inner2 {
    background: none repeat scroll 0 0 #000000
    margin: 0 7px 0 0 !important;
    padding: 0 !important;
    change it to
    I hope that helps!
This topic contains 4 replies, has 2 voices, and was last updated by  Sherlock 12 years, 7 months ago.
