  • lama82 Friend
    #206191
    thank you for this great Plugin!
    It works fine on the website when used by itself. Further down the site I am using it together with the Vertical Content Accordion from Contona and then the Map doesn’t show properly anymore. I am trying to solve this problem but I don’t know if the problem is with the Accordion Module or with your Google Map Plugin. Do you have any ideas on how to solve this?
    Thank you,
    Laila
    Adam M Moderator
    #570170
    Hi @lama82,
    Could you please clarify a little bit more about the problem as I checked your site but see that Google Map works fine there ?
This topic contains 2 replies, has 2 voices, and was last updated by  Adam M 9 years, 6 months ago.
