February 4, 2013 at 9:22 pm #184679
As you can see from the printscreen, a white band appears at bottom of page.
Only when I’m on a big screen (21 inches screen) and on an article.Do you have a solution?
You can test the website: http://bierinov.lescigales.org/
Thank you for your help.
Sorry for my english.
Greetings.
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
February 4, 2013 at 11:30 pm #482415I think it is because you have got your background only applied to the JA-Wrapper div.
Instead apply the code change to template.css line 9 in /templates/ja_tiris/themes/orange/css/template.css
body#bd {
background: url("../images/bg-body.png") repeat scroll 0 0 transparent;
color: #7B7B7B}
Then place your background image in the images folder so that it is in the correct path for the above.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Phill 11 years, 11 months ago.
Problem: white stripe
