July 6, 2015 at 2:16 pm #208342
Dear Sirs
I have been struggling in the activation of modules and plugins. Specifically when I try to activate them in the layout nothing happens .
I would like to turn the languangeswitcherload , then choose the default location on select layout and then saved. The saving occurs but continues to none . What should I do to solve this problem ?
and
July 7, 2015 at 2:20 am #576552Hello
When you hover on the module position you will see an icon to edit the position .
Here >> http://prntscr.com/7powrm
Click on it and add the module position , like this >> http://prntscr.com/7pox8b
Do the same for other two position .
Hope it help.Pankaj Sharma ModeratorPankaj Sharma
July 7, 2015 at 2:20 am #642865Hello
July 7, 2015 at 2:20 am #741522Hello
Hope it help.July 7, 2015 at 1:22 pm #576615Hello pankajsharma ,
Sorry, I do not think I explained right . After I click choose the modules (switch module) . After this I click save but the settings revert to none .
July 7, 2015 at 1:22 pm #642928Hello pankajsharma ,
July 7, 2015 at 1:22 pm #741585Hello pankajsharma ,
July 8, 2015 at 2:24 am #576660Hello
You are using older version of template and T3 plugin .
Please update both via JA Extension manager component .
Then Compile Less To css from template options .Do not forget to take a full site backup and backup of custom changes before updating template and t3 plugin .
July 14, 2015 at 1:57 pm #577361Hello !!
I already managed to make the necessary changes , but I realized that the name of the languages in the module ( languageswitcherload ) ” English – UK and PortuguesBrasileiros -Pt -Br ” is written in a wrong way .
I need to change the name within the module :
of PortgusBrasileiro -Pt -br to Portuguese
of English-UK to English
How can I do that?
July 14, 2015 at 1:57 pm #643666Hello !!
How can I do that?
July 14, 2015 at 1:57 pm #742313Hello !!
How can I do that?
July 14, 2015 at 2:05 pm #577363Already solve! TKS !
July 14, 2015 at 2:05 pm #643668Already solve! TKS !
This topic contains 14 replies, has 2 voices, and was last updated by rlandrade 9 years, 3 months ago.
