funci Friend
funci
- February 2008
- 5 times in 2 posts
March 23, 2017 at 6:36 pm #1021419Hi guys,
I can’t get main menues visible when I am changing languages. For default language (HR) everything is working fine. When I want to switch to another language (EN and IT) I can see proper content, but main menu for that language isn’t visible.
Please, can somebody check it?
Saguaros ModeratorSaguaros
March 24, 2017 at 8:24 am #1021558Hi @funci,
JA Mendozite is built with old JAT3 v2 framework, the multilingual need to configure via Template Profiles in: Admin Panel > Extensions > Templates > JA Mendozite > Profile tab
The default style is assigned to HR menu on your site already so to show menu for IT or EN, you can:
- Duplicated ‘default’ profile under Profiles tab to have a new one called ‘default-IT’ for example
- Under this new ‘default-IT’ profile, you can set the IT menu for it
- Assign this profile to accordingly page via Menu assignment tab
I helped you to configure for IT menu, you can apply the same for EN menu.
funci Friendfunci
- February 2008
March 24, 2017 at 10:54 am #1021649Thx Saguaros,
I don’t know am I doing right…
Only what I can get that working properly is only 2 languages at the same time. When I set the third language than one of first two isn’t working.
Please can you check it?Saguaros ModeratorSaguaros
March 25, 2017 at 2:17 pm #1021793You will need to assign the Profiles of certain language to associated menu item page: http://prntscr.com/eoavx9
I updated for you and you can see it works now.
Kindly check.
funci Friendfunci
- February 2008
March 27, 2017 at 10:54 am #1022178Hi Saguaros,
I’ve did all that steps and it is good for two languages. When I am trying to add third language than one of the first two languages is dropped out.
Please can you try to test that?Saguaros ModeratorSaguaros
March 28, 2017 at 6:37 am #1022469It’s weird, I just tried to add for EN and it’s good now, kindly check.
funci Friendfunci
- February 2008
March 28, 2017 at 9:37 am #1022525Yes, it’s weird!
Now good are HR and EN… IT don’t works…Saguaros ModeratorSaguaros
This topic contains 9 replies, has 2 voices, and was last updated by Saguaros 7 years, 9 months ago.
