  • melou61 Friend
    #1044435
    A problem that i found is in the next picture, first, the budget should be in line with the bids and average bid, instead of down them. Another problem would be the white background. How to solve this?
    1. Captura-de-pantalla-2017-06-22-a-las-8.42.13
    Pankaj Sharma Moderator
    #1045144
    Can u share the page URL on which this screenshot part is showing?
    So that i can check this issue on your site.
    melou61 Friend
    #1045186
    #1045208
    Which background you want to apply.
    Its coming from
    /templates/ja_events_ii/local/css/themes/acz/template.css
    .well {
        background-color: #ffffff;
        box-shadow: none;
    melou61 Friend
    #1045252
    I just added it and clear cache, but still the same
    1. Captura-de-pantalla-2017-06-30-a-las-12.04.40
    #1045531
    Kindly clear cache and check.
    Its working fine http://prntscr.com/fqvwi6
    melou61 Friend
    #1045686
    Its ok now, thanks
    #1045820
    You are welcome!
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 5 months ago.
