  • marco17 Friend
    #150712
    i have problem with accent, the character with accent are not showed, instead of them a symbol is showed.
    This happens only the characters are placed in .ini files in languages folders.
    If i put an accent character in the normal text of the article or module it is showed, but if i put an accent character in the es.ES.name_of_module.ini in the ES folder it is not showed (a symbol is showed).
    Can you help me ?
    Thanks in advance.
    Anonymous Moderator
    #342387
    Hi marco17
    It is very strangle. I think you have made a mistake
    Could you give me your live url, ftp account via PM so that i could have a closer look on the issue?
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 14 years, 7 months ago.
