  • akamamex Friend
    #204076
    Hi, i am using the ja books template, i used the quick start and configured as the guide. but the accordion module is broken ( see attachment), the best seller module look and feel is not the same as that of the live demo and for some reason the category module is not displayed on the side bar, i need your help
    regards
    chavan Friend
    #560604
    Have you followed the exact way as it is in this image
    1. accordion-module
    akamamex Friend
    #560621
    thanks this helped a lot i know can see the accordion module, can you also take a look at the best seller configuration (see attachment 1) but result is (see attachment 2) and i could not have the category module work
    regards
    1. attachement1
    2. attachement2
    chavan Friend
    #560779
    adding three more products to the best seller will fix the spacing automatically.
This topic contains 4 replies, has 2 voices, and was last updated by  chavan 9 years, 10 months ago.
