  • griff1324 Friend
    #140046
    I am using JA Tabs in the content of my article. Here is the last half of the HTML code that I am using in the content:
    {jatabs type="content" position="left" widthTabs=225 mousetype="click" animType="animFade"}
    <table class="specs_content mceVisualAid" width="100%">
    <tbody>
    <tr>
    <td class="mceVisualAid" colspan="2"><p class="specs_heading">Specifications:</p></td>
    </tr>
    <tr>
    <td class="mceVisualAid" valign="top" width="50%"><ul class="bullet-2">
    <li>Seasoned Six Bolt Block Decked .020</li>
    <li>Cast Iron Precision Ground Micro Polished Crankshaft</li>
    <li>Speed-Pro or Keith Black Hypereutectic Coated Skit Pistons</li>
    </ul></td>
    <li>Melling Oil Pick Up</li>
    <li>Chrome Front Sump Oil Pan and Dip Stick</li>
    <li>New Aluminum Timing Cover with Scale</li>
    <li>Edelbrock Performer Series Intake Manifold</li>
    </ul></td>
    </tr>
    <tr>
    <td class="mceVisualAid" colspan="2"><p>jdf aladjf djfla jf;lakjf jdfl;ajf jkfajf f;jkfaj</p></td>
    </tr>
    <tr>
    <td class="mceVisualAid" colspan="2"><span class="pricing">Ford 302 ci Naturally Aspirated Turn-Key Crate Engine - Only </span><span class="pricing">$5,565</span></td>
    </tr>
    </tbody>
    </table>
    <tbody>
    <tr>
    </tr>
    <tr>
    </ul></td>
    </ul></td>
    </tr>
    <tr>
    <td class="mceVisualAid" colspan="2"><p>dfajh jahf ahflh afhlkajdfh falkdhfalkhf ahdfklah afhkafh fadfaf</p></td>
    </tr>
    <tr>
    <td class="mceVisualAid" colspan="2"><span class="pricing">Ford 302 ci Naturally Aspirated Turn-Key Crate Engine - </span><span class="pricing">Only $6,250</span></td>
    </tr>
    </tbody>
    </table>
    {/jatabs}
    {loadposition testing}
    If I remove {loadposition testing} everything works fine. If I write regular text after {/jatabs} then everything works fine. The moment I add any type of code (ex. <br>, {loadposition test}, <table>, etc) I have problems when viewing in Internet Explorer. In IE, the page will begin to load and then IE starts sucking up the CPU resources of the PC and the page never fully loads.
    If I view the page in FireFox everything looks great. Any ideas what the problem is and how to fix it?
    Chris
    fabiomartelli Friend
    #300685
    hi i think the are some problem with the layout. Try to ceck with firebug if there are some invisibile part (due to an overflow hidden propriety) overflowing the area of the plugin….
    If you want link your page
This topic contains 2 replies, has 2 voices, and was last updated by  fabiomartelli 15 years, 8 months ago.
