  • brentwilliams2 Friend
    #682430
    When adding a new admin to the system, if they are a Super Admin, they have all of the Permissions checked and can’t be edited. If the user is a Joomla “Administrator”, however, there are default permissions checked, such as “Permission Management”, “Category Management”, etc. When I try to check/uncheck any of these and save, the results don’t save. In fact, I can’t find anywhere in the database where they would actually save to.
    So, my question is whether this part of the component actually is working, and if not, is there simply a way to have Joomla Administrators have all permissions by default, like Super Users do?
    Mo0nlight Moderator
    #684051
    Hi brentwilliams2.
    You can edit the file : components/com_jajobboard/helper/jafunctions.class.php
    line :2161
    Change :
    [PHP]if(JBAccess::isSupperUser($user->id)) {[/PHP]
    To :
    [PHP]if(JBAccess::isJbAdmin($user->id)) {[/PHP]
    Then administrator account will have permission to management all jobboard menu.
    BigHug Friend
    #748619
    Hi brentwilliams2.
    line :2161
    Change :
    To :
    #684958
    Hi Moonlight,
    Thanks for the reply, but that did not work, unfortunately. Is it possible it is not working because she is also an employer?
    #748811
    Hi Moonlight,
    Mo0nlight Moderator
    #686192
    Hi brentwilliams2.
    It’s weird! maybe it happens on your site only, ps take a backup of your site and PM me FTP account of your site, I will check it further for you.
    Regards,
    BigHug Friend
    #748989
    Hi brentwilliams2.
    Regards,
This topic contains 7 replies, has 3 voices, and was last updated by  BigHug 9 years, 2 months ago.
