  • librandi Friend
    #887701
    I have this problem when I open a article from this page http://www.pirripirri.it/it/i-nostri-clienti.html,
    if I open an article I see Fatal error: Class ‘JATempHelper’ not found in /home/fisnzmpg/public_html/templates/uber/html/com_content/article/product.php on line 34 .
    Can you help me please?
    The error is showing because your categories are missing of the Extra-field tab, where you assign an extrafield type at your articles belonging to that specific category, in your case the extra field is product as you can see from my image below.
    I don’t know why it is missing, because i don’t know how you installed it and which files are modified, i can suggest as solution to take a backup and try to reinstall the uber template from Joomla extension manager.
    1. Screenshot_5-3
    librandi Friend
    #887921
    Ciao,
    ho reistallato il template ma non compare extrafield cosa posso fare?
    PS:ti ho lasciato un messaggio su skype guardalo please!
    Non ho ricevuto nessun messaggio – puoi rimandarlo ?
This topic contains 3 replies, has 2 voices, and was last updated by  pavit 8 years, 10 months ago.
