July 12, 2010 at 12:38 pm #152479
When i set the anion as the default template i receive blank page saying:
Fatal error: Undefined class name ‘t3template’ in /home/content/mysite/templates/ja_anion/index.php on line 2
Also when i try to edit the template i get this:
and when i try to install the JA T3 System plugin for Joomla 1.5 i receive message
Parse error: syntax error, unexpected ‘,’, expecting ‘(‘ in /home/content/mysite/plugins/system/jat3/core/common.php on line 147 in frontend and backend
Could you please give me some ideas what is the problem? I have the latest version of joomla.
Thank you in advance!
July 14, 2010 at 2:19 pm #349918I’m also getting the same errors – this template is broken – should be tested before being available for download
- 1334 times in 848 posts
July 14, 2010 at 4:15 pm #349928dear Huski,
Can i have the site login and ftp details via PM? Let me try and fix it up for you.
Arvind
July 14, 2010 at 5:47 pm #349937Same problem here.
Parse error: syntax error, unexpected ‘,’, expecting ‘(‘ in plugins/system/jat3/core/common.php on line 147 in frontend and backend.PHP Version 4.4.8
July 14, 2010 at 10:00 pm #349950Please..any reply?
Saguaros ModeratorSaguaros
July 16, 2010 at 7:05 am #350047Sorry, can you please submit a ticket about this issue, our developers ‘ll check this
thanksJuly 16, 2010 at 4:08 pm #350082same problem! Please Help!
- 2008 times in 1700 posts
July 19, 2010 at 2:52 am #350196<em>@kbtobegoo 186707 wrote:</em><blockquote>same problem! Please Help!</blockquote>
Hi guy,
please submit a ticket about this issue, our developers shall check the issue for you.
July 19, 2010 at 6:09 pm #350268And I get this one: Warning: file_put_contents(/home/user/domains/mysite.nl/public_html/niro/templates/ja_anion/css/menu/split.css) [function.file-put-contents]: failed to open stream: Permission denied in /home/user/domains/mysite.nl/public_html/niro/plugins/system/jat3/core/preload.php on line 107.
Nice template in demo, but it is the first of the 92 that i can’t use.Saguaros ModeratorSaguaros
July 20, 2010 at 3:56 am #350284Hello JanKoen!
I have create the issue, our developer will check this, http://pm.joomlart.com/browse/JATCANION-127,
thanks1 user says Thank You to Saguaros for this useful post
mychaello Friendmychaello
- March 2009
- 2 times in 1 posts
July 21, 2010 at 9:22 am #350387hi all, i have blank page too after use Anion template
when i use another template, frontpage is ok. i can try enable debug system, but blank page on frontpage still, no errors writen …any idea? thanks
my Anion template configuration page is view like this:
and not view like this:
July 28, 2010 at 1:53 am #350984Dear mychaello!
Which verion do you use? because the template have released version 1.2.0, pls try to upgrade for yours again and if the problem is not fixed, pls submit tickets contain accounts information, we ‘ll try to find, resolve the bug
- March 2009
July 28, 2010 at 9:37 am #351032Hi tienhc,
I upgrade to latest version and my problem is solved.Thank you 🙂
July 30, 2010 at 12:57 am #351218yet another website with same error:
Fatal error: Class ‘T3Template’ not found in /home/timefix/public_html/members/templates/ja_anion/index.php on line 2I really do not see a point in submitting a ticket since so very many people have the same problem. It is obviously something in this beautiful template causing the problem.
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
July 30, 2010 at 9:46 am #351242<em>@ekwade 188216 wrote:</em><blockquote>yet another website with same error:
Fatal error: Class ‘T3Template’ not found in /home/timefix/public_html/members/templates/ja_anion/index.php on line 2I really do not see a point in submitting a ticket since so very many people have the same problem. It is obviously something in this beautiful template causing the problem.</blockquote>
JA Anion is a T3v2 template, therefore, you need install plugin jat3 and enable it to make this template function.
This topic contains 15 replies, has 11 voices, and was last updated by Khanh Le 14 years, 5 months ago.
