  • xaxareena Friend
    #192978
    i installed qiuck start of j3.1
    but i think , it’s not orginal because
    i change my lang to arabic (persian) then when i try to edit Home-menu to our language => صفحه نخست
    it saved like ????? ????? 🙁
    i think your db is not utf-8
    http://digitalbranding.ir/basakk/
    Manos Moderator
    #515452
    The db files that the QS package installs are whatever your hosting environment supports by default, i suggest that you create a new database set it to utf8_general_ci and then try to reinstall the QS package again.
    Manos
This topic contains 2 replies, has 2 voices, and was last updated by  Manos 11 years, 1 month ago.
