  • tiska Friend
    #146861
    I am having a problem with an article on the front page of my site. One article is an odd shape – you can see it on my test site here: http://www.my-portfolio.gr
    It is the article called ‘How we support out community’. It should be the same ‘shape’ as the artcle above it but it is one very thin column instead 🙁 🙁
    Can anyone help me?
    Thanks,
    Tiska :confused:
    Anonymous Moderator
    #326783
    Hi tiska
    I have tried to find your issue but could not find.
    Could you give me the screenshot so that i could have a closer look on the issue?
    tiska Friend
    #326804
    I enclose a screen shot here. You can see that the article on the left at the bottom of the page is in a v thin column. It should be like the one above it in column width, I think.
    Thanks!
    1. Picture-1
    Anonymous Moderator
    #326973
    Hi tiska
    Your image is very small. I have checked your website on FireFox, IE7, 8, Safari – Window Vista but could not find this isuse.
    I will report this issue to our mods for checking.
This topic contains 4 replies, has 2 voices, and was last updated by Anonymous 14 years, 11 months ago.
