February 27, 2011 at 3:35 pm #160773
When I set a menu option to call a particular article, the modules in the right column does not appear. Several of the modules are set to appear on all menu items.
The same article on the front page does not have problem.
gray Friend
gray
- October 2009
- 292 times in 230 posts
February 27, 2011 at 3:53 pm #378616Do you work with one and the same menu (eg. not creating a new menu item, but just reassign its type and properties?).
If yes, check menu item parameters, if no try to use the same menu (it’ll have same ID and modules assigned to it should not disappear).February 27, 2011 at 5:13 pm #378630Apparently this is not the problem. I tried with new menu options and reusing others. The problem is only with the new options from mainmenu.
gray Friendgray
- October 2009
February 27, 2011 at 6:37 pm #378638<em>@msilvestrini 224105 wrote:</em><blockquote>Apparently this is not the problem. I tried with new menu options and reusing others. The problem is only with the new options from mainmenu.</blockquote>
It means that you should check module assigning settings. Those modules which have “Varies” in Pages column on Module Manage page are configured to be displayed only on certain pages (read – linked to menu items). If you create a new menu check every module with “Varies” value if you want it to be displayed on newly created menu page.
Viewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by gray 13 years, 10 months ago.
