  • gentgashi Friend
    #198089
    Not sure if this has got to do with the template or Joomla itself but whenever i am trying to share some article with link as follows http://studemic.com/index.php/blogu/elementet-e-faqes-se-pyetjes Facebook is sharing the home page of the site and not the specific article. Maybe it has got something to do with “index.php” after the page name, but I don’t know how to remove it.
    Pankaj Sharma Moderator
    #536357
    hello @gentgashi
    This problem is not coming from the template .
    it is due to the html error present in the page .
    You can see the html on http://validator.w3.org
    here is the result of your page
    Hope it helps
    gentgashi Friend
    #536443
    Ok I have cleared a lot of my errors now there are 3 errors coming from the template. Any idea how to remove them ?
    #536476
    <em>@gentgashi 428957 wrote:</em><blockquote>Ok I have cleared a lot of my errors now there are 3 errors coming from the template. Any idea how to remove them ?[/QUOTE
    Did you reported this issue to the facebook developers??
This topic contains 4 replies, has 2 voices, and was last updated by  Pankaj Sharma 10 years, 8 months ago.
