hamlethub Friend
hamlethub
- February 2011
- 3 times in 1 posts
August 11, 2011 at 12:02 pm #167283When we post an article, it appears under the category, but does not appear correctly in the JA newspro module. Eventually, after about 6 hours, it does appear correctly.
I have tried refreshing while viewing, and using ctrl-F5, and it still does not appear.
I believe this could be a problem with the cache?
The value that is in the cache, in JA-Newspro, is that in seconds?
Thanks,
Ken
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
August 11, 2011 at 12:06 pm #405640Hello,
If you go to the ->Advanced Parameters of Ja NewsPro you will see the time for cache!
But you can also clear cache every time you post a new article.I hope that helps!
hamlethub Friendhamlethub
- February 2011
August 11, 2011 at 4:36 pm #405722<em>@pascm 258969 wrote:</em><blockquote>Hello,
But you can also clear cache every time you post a new article.I hope that helps!</blockquote>
What does that number mean, seconds? minutes?
Do you think that could be why articles are appearing under the categories, but not showing up in the main part of the janewspro?
- February 2014
August 11, 2011 at 5:24 pm #405733Hi, that number is in minutes (although i am not 100% sure).
What do you mean by <em>@hamlethub 259068 wrote:</em><blockquote> Do you think that could be why articles are appearing under the categories, but not showing up in the main part of the janewspro?</blockquote>If you have included the categories in JaNewsPro settings then articles from those categories should show up.
- February 2011
August 11, 2011 at 5:59 pm #405741<em>@pascm 259080 wrote:</em><blockquote>Hi, that number is in minutes (although i am not 100% sure).
What do you mean byIf you have included the categories in JaNewsPro settings then articles from those categories should show up.</blockquote>
They show up, but only after about an hour, or longer. In the meantime, they do appear in other places, just not where they are supposed to show up in the JA NewsPro module.
Ken
- February 2014
August 11, 2011 at 6:01 pm #405743That’s because of cache time!
You can disable cache (Not suggested) and what i do -> http://www.istories.gr is clear cache each time a new article is on!
Goto -> Tools- Clean Cache – Clean everything ! And you are done!
I hope that help you!
This topic contains 6 replies, has 2 voices, and was last updated by Manos 13 years, 4 months ago.
