  • Perry Friend
    #1029385
    I have problems displaying the features intro template on my mulilanguage homepages. I have created a features intro template for each language homepage. And a default template for each languages content pages. But the features intro template will only show if I set it as default language homepage and then it becomes assigned to all pages in a language whether it is ticked as assigned or not.
    I want to assign features intro de, features intro es & features intro de templates to their respective language homepages.
    Please help.
    P.S. I have posted recently on this subject but need a quicker response hence the premium ticket.
    Thanks in advance
    Pankaj Sharma Moderator
    #1029482
    I checked your site and noticed you recently updated your Joomla that create this issue.
    There is issue in the Joomla. as u can try to set default Joomla template to any menu item it still load only default template.
    http://prntscr.com/f1ovzk
    http://prntscr.com/f1ow2o
    I suggest you to Restore the working site backup you did before update Joomla.
    Also wait for the template and T3 update too for the latest Joomla version.
    And update the Joomla after template and all other extension ar ready for it.
    Perry Friend
    #1029638
    Hi Pankaj,
    I see a mention that your are working on template updates for 3.7 and hope to roll out within th next week. It may be worth us waiting rather than rolling back. Will Ja Sugite be included in thiese updates?
    Thanks in advance
    #1029640
    Its not the temple issue. There is something wrong on Joomla as u can see its same if u assign default Joomla template.
    I suggest you to test updates in local host.
    Perry Friend
    #1029657
    Hi Pankaj,
    If I restore to 3.6.5 can to look into the issue for me?
    #1029941
    Hi Perry
    I noticed co-worker already working on the same issue for you here
    For the assignment, if you have same issue in the Joomla3.6.5 this is something that is not from the template. I suggest you to put the question on Joomla forum community, that template assignment is not working in your Joomla.
    try to set default Joomla template to any menu item it still loads only default template.
    This is something wrong in the Joomla menu system.
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 8 months ago.
