  • dpapan Friend
    #152477
    When i set the avian as the default template i receive blank page saying:
    Fatal error: Undefined class name ‘t3template’ in /home/content/mysite/templates/ja_anion/index.php on line 2
    Also when i try to edit the template i get this:
    and when i try to install the JA T3 System plugin for Joomla 1.5 i receive message
    Parse error: syntax error, unexpected ‘,’, expecting ‘(‘ in /home/content/mysite/plugins/system/jat3/core/common.php on line 147 in frontend and backend
    Could you please give me some ideas what is the problem? I have the latest version of joomla.
    Thank you in advance!
    Arvind Chauhan Moderator
    #349681
    Dear Dpapan,
    Avian Template does not support T3 framework. Are you using JA Anion? If yes, please report the above in JA Anion Forum.
    Arvind
    dpapan Friend
    #349682
    Yes, Anion! Sorry…
    Thank you, i will post it there
This topic contains 3 replies, has 2 voices, and was last updated by  dpapan 14 years, 5 months ago.
