  • tbezner Friend
    #160538
    Hi, I really like the Teline IV template. I’ve had problems with Rave, so I’m heavy in development of a J1.6 port of our site.
    One nagging issue- some articles are backgrounded yellow- like the “Featured” option is on. I can’t seem to make this go away. Please see attached jpg for an example of how it looks.
    Phill Moderator
    #377844
    Can you re-post the images as I cannot see it. A link to your site would also be helpfull
    tbezner Friend
    #377845
    Sorry, I forgot to attach the JPG. I edited my post- it is there now.
    The site is hosted on a local closed-off server for now. Can’t send you a link currently.
    Tracy
    Ninja Lead Moderator
    #377893
    dear tbezner, since I can not see you site, its kinda hard to suggest anything, but I guess your article content contains some styles which produce that result, try to clear styles in the article to see if it works.
    tbezner Friend
    #378005
    I figured it out. It isn’t the article styles. They were all clear.
    It is the menu type “Category Blog” I was using. I consolidated the articles into one big one, changed the menu items to “Single Article” and background coloring disappeared.
    Just a note to the developers- it would be good to have that background coloring as something that is switchable on/off.
This topic contains 5 replies, has 3 voices, and was last updated by  tbezner 13 years, 10 months ago.
