softchris4ol Friend
softchris4ol
- October 2013
August 1, 2014 at 7:11 pm #200184Hi,
I was working on something concerning Hikashop Payment application. I noticed that the Banner of my web site does not show on all the pages.
Check when you click on a particular product, you will observe that the Banner space is blank. The Banner shows only on the Home Page, but does not show on other pages.
I have tried all I could, but I was unable to resolve the issue.
Please, how can I make the Banner to show on all the Pages of my store.
softchris4ol@gmail.comsee attached
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
August 1, 2014 at 7:23 pm #544215To which banner are you referring?
Perhaps a screenshot to help us see/investigate the issue more clearly?
softchris4ol Friendsoftchris4ol
- October 2013
August 2, 2014 at 2:57 am #544226ToMc. I have updated my request with the Image.
Note that I am not sure of what caused this problem. Everything was working normally until I tried to edit a Hikashop file, which turned everything upside down. And when I reverted to the default setting of the file, the error persisted.
Thank you; as you investigate the issue
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
August 4, 2014 at 10:06 am #544417Hi,
Could you please provide your site url so I can take a look ? In addition, please clarify a little bit about the file you want to modify and the code you want to change, it would helps us assist you better.
TomC ModeratorTomC
- October 2014
August 4, 2014 at 5:47 pm #544496<em>@softchris4ol 439146 wrote:</em><blockquote>ToMc. I have updated my request with the Image.
Thank you; as you investigate the issue</blockquote>
What Hikashop file did you try to edit (before the issues began)?
- October 2013
August 4, 2014 at 6:43 pm #544502I have reverted the changes I made to the file
Display-View-JAMitius Template-Checkout View. Check the ‘step’ files.I added a line of text at the top of the code file. But, I’m not sure this is the problem
Just check and see what you can do.
- May 2014
August 5, 2014 at 7:29 am #544583Hi,
Could you please send updated php file via private message so I can take a look for you ?
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by Adam M 10 years, 3 months ago.
Problem with Banner – JA Mitius – Very urgent
