  • tresoar Friend
    #208904
    I have a banner with this code <div class=”main-container clearfix”>
    <div class=”text-banner”>
    <p>Not sure what to do?</p>
    <p>The advice Nurse will help you figure it out</p>
    </div><a href=”index.php?option=com_content&view=article&id=173&catid=9&Itemid=565″ class=”btn btn-border”>Make an appointment</a>
    </div> with features intro position. At first the banner looked like this
    Now it looks like this There is now white space on the left and right side of the banner. I don’t know how. How can i remove the white space?
    Also the bulletlist on positon 1 has changed. There is now less space between the border of the square and the bulletlist. I hope someone can help me solve that problem too.
    Pankaj Sharma Moderator
    #577777
    Hello
    Both of your issue are due to the custom code by you for creating padding in t3 modules .
    remove the padding code from custom.css .
    here >> http://prntscr.com/7tojy1
    #644071
    Hello
    #742706
    Hello
    tresoar Friend
    #577780
    Thanks, that’s it. I copied this code from firebug.
    Like here on the website http://www.joomlart.com/demo/#ja_medicare
    tresoar Friend
    #644074
    tresoar Friend
    #742709
    #577787
    You have not need to define additional css as your template already contain the all the css files . Also the module does not contain any padding . so can remove it .
    Template have all the code already , do not add additional codes for the screenshot css changes for different modules/screen size . do not worry about that .
    #644081
    #742716
This topic contains 10 replies, has 2 voices, and was last updated by  Pankaj Sharma 9 years, 5 months ago.
