  • neurdenburg Friend
    #153524
    I want to place two banners one beneath the other in the right module position. However when I have the title headers activated the lay-out is broken. It appears as if one of the banner images is rendered inside the header although judging from the source this is not the case?
    Can anyone point me in the right direction?
    http://www.stfinbarrs.net/music.html
    See example image below:
    Css Magician Friend
    #352882
    Please go to template.css line 753 and remove float: left as follow:
    div.advs {
    clear:both;
    display:block;
    width:100%;
This topic contains 2 replies, has 2 voices, and was last updated by  Css Magician 14 years, 4 months ago.
