  • osola Friend
    #193935
    Hello!
    I have a problem with columns when I use category blog in Beranis template.
    As you can see in the image with 2 or 3 columns you get free spaces with no post in the blog.
    Tnks!
    1. 2columns
    2. 3columns
    Ninja Lead Moderator
    #519347
    You can try to do this way
    Open templates/ja_beranis/css/themes/escola/template.css file and add this script
    @media (min-width: 768px) {
    article {
    margin-right: 15px !important;
    osola Friend
    #519505
    I wrote exactly the text at the end of the file template.css, but nothing has changed…
    I can not understand what the @ in the text means. And what do you mean by script?
    Thanks for your answer!
    #519621
    I did help to modify directly on your site in templates/ja_beranis/css/themes/escola/template.css file:
    Change
    .media (min-width: 768px) {
    article {
    To
    article {
    About @ before media tag you can have look at this link for reference.
    Please check your site again. Let me know if it helps.
    osola Friend
    #521937
    I’m sorry but this don’t solve the problem..
    #522003
    <em>@osola 410381 wrote:</em><blockquote>I’m sorry but this don’t solve the problem..</blockquote>
    I could not find the menu on your site with Category Blog that has 2 or 3 columns. Please help to create that page (with 2 or 3 column). I will investigate further.
This topic contains 6 replies, has 2 voices, and was last updated by  Ninja Lead 10 years, 9 months ago.
