October 5, 2015 at 5:49 pm #695396
I want to add new icon in Box IconI want to add user-plus Unicode: f234
I follow the step :
1- templatesja_medicarecsstemplate.css to:
.t3-module.box-icon-user-plus:before {
content: “f234”;
}2- templatesja_medicarefontsfont-awesomecssfont-awesome.css to:
.fa-user-plus:before {
content: “f234”;
}in my module I use class suffix : box-background-dark box-icon box-icon-user-plus
but nothing appear in front ….. I have a square with inside F234 ….
I don’t understand….
Best regards
October 6, 2015 at 1:22 am #695484Hi
Kindly share your working site url here , and Turn Off the CSS compression from template options , So i can check it directly on your site.Pankaj Sharma ModeratorPankaj Sharma
October 6, 2015 at 1:22 am #750680Hi
Kindly share your working site url here , and Turn Off the CSS compression from template options , So i can check it directly on your site.October 6, 2015 at 6:24 am #695563Hi thanks for your answer
I have Turn Off the CSS compression from template options
but it s not working
I send you a private message
Best regards
October 6, 2015 at 6:24 am #750712Hi thanks for your answer
Best regards
October 6, 2015 at 10:26 am #695604Hi
we used font awesome icons . on your site you are using older version of font awsoe that does not contains the code of icon .
Kindly take a full backup of site . Update T3 plugin to latest version . Take backup of all custom changes then Compile Less to css and check it .1 user says Thank You to Pankaj Sharma for this useful post
October 6, 2015 at 10:26 am #750753Hi
October 6, 2015 at 11:29 am #695699Hi,
I update the template 1.1.4 and t3plugIn 2.5.1
but its nor working
finally I download font awesome icons in ja_medicare 1.1.4 it s font awesome 4.2.0
I uplaod the file from awesome 4.4.0 and it’s working
Thanks again
Best regards
October 6, 2015 at 11:29 am #750768Hi,
but its nor working
Thanks again
Best regards
This topic contains 9 replies, has 2 voices, and was last updated by bullitt 9 years ago.
