  • joomlachile Friend
    #192251
    Hello
    On my website with joomla 2.5 (with lots of visitors) the caching system breaks the entire style of the web when its recreated, i have opened a ticket but i got no response so far, so i am opening this if i can get help.
    I have setup the join and minify option for both css and javascript files, plus the cache system of joomla with a lifetime of 60 minutes.
    The server is lighttpd + varnish caching system maybe this has something related to it.
    I hope you can help me. Thanks.
    Hi joomlachile,
    If you’re enabling cache option of JAT3 framework, please try to disable Joomla cache system. You can PM me URL to access backend of your site and details the error here, I will try to check for you
    joomlachile Friend
    #512740
    Thank you, i will PM you with the info. Regards
    I just enable template cache feature and disable system cache plugin but your site still shows fine. Please have a look at this again.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 11 years, 1 month ago.
