  • albertorossi Friend
    #122332
    I try to install a componetn (and relative modules) for a calendar (jcalpro adn some other) on my teline but the modules don’t work.
    with other template the modules work good… i think that it not is a modules truoble.
    you can suggest a solution or another modules
    tnk
    Menalto Friend
    #228143
    Do you have a live site so we can take a look at i t?
    albertorossi Friend
    #228145
    yes, of course
    http://www.monteverdedemocratico.it/sito2/
    all the link on template have “option=” ….. and is no good for the modules…
This topic contains 3 replies, has 2 voices, and was last updated by  albertorossi 17 years, 3 months ago.
