  • iguinee Friend
    #731768
    Hi, I have followed all the threads relating to this issue, but I cannot fix it. I can’t make the captions appear on articles on my Joomla! 3.x site – with Teline 5 template.
    Adam M Moderator
    #752750
    Hi @iguinee,
    You can check my answer in this thread.
    iguinee Friend
    #752804
    I have followed these instructions, in vain.
    Can you please check it for me? I have left the details for the Admin and Support staff.
    Many thanks.
    Adam M Moderator
    #752902
    Hi @iguinee,
    Please also provide a temporary FTP account via private reply as well, I will check this matter for you then.
    iguinee Friend
    #753193
    I have installed the component extplorer which can allow you to access all files and folders. Please try using it as you should not have any trouble.
    Adam M Moderator
    #753322
    Hi @iguinee,
    You should see the caption in your site now.
    iguinee Friend
    #753651
    Hi @adam M,
    Thank you for your support in this matter. I have just checked some articles, but I do not seem to see the caption. Check this article for instance.
    Thanks again.
    Adam M Moderator
    #753706
    Hi @iguinee,
    Just wait for the site to finish loading and you will see image caption there.
    iguinee Friend
    #753730
    Hello @adam M,
    Thank you so much for this help.
    I can now see the caption for the main article image. However, the caption for the in-text picture is not appearing. You know, when you insert other pictures inside the article, those pictures do not have the captions showing. Check out this article for instance – you can see the caption for the main picture appears, but the caption for the second image whish is a map.
    Thank you for your continuous support in this matter.
    Adam M Moderator
    #753802
    Hi @iguinee,
    For image in body content, please install JCE Editor, this editor has function to let you insert image caption, more detail can be found here.
    iguinee Friend
    #754327
    Many thanks for that.
This topic contains 11 replies, has 2 voices, and was last updated by  iguinee 9 years, 1 month ago.
