  • magiur Friend
    #145895
    Hi!
    I had install Teline II, configured, but when I click on the links in the bar menu, appear the message:
    Fatal error: Call to a member function get() on a non-object in /web/htdocs/scuola.impegnarsiserve.org/home/modules/mod_janews/helper.php on line 36
    If I chance in the type in the menu item and not use Category Blog Layout it run correctly.
    Why?
    Magiur
    Anonymous Moderator
    #323697
    Hi magiur
    Please let me know your version of joomla. I think you are using the old version.
    You should submit a ticket, send us your live url, admin account, ftp account so that we have a closer look on the issue.
    Hello magiur!
    The issue has fixed, please kindly re-download the teline 2 package and then upgrade some files as following:
    1) all files in the “/templates/ja_teline2/html/com_content” folder
    2) all files in “/modules/mod_janews”;
    magiur Friend
    #323737
    Ok, it show the articles now… but appear a message
    <blockquote>No valid database connection You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘order by t.weight’ at line 1 SQL=select t.name from jos_tag_term as t left join jos_tag_term_content as c on c.tid=t.id where c.cid= order by t.weight</blockquote>
    The problem is raising on your site, it’s not from JA Extensions.
    To debug this issue, Please kindly turn off some extensions which have installed.
    I guess it is a plugin has type is content, may be the extension use for Tagging, and the extension is related ” jos_tags_term” table and ” jos_tag_content” table, those table are not built-in joomla.
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 15 years ago.
