  • aluduarte Friend
    #970324
    Hi. Im having a problem in one section of my site, which was builded with Musik Template.
    In the video section it shows up this error code below, and i cant fix it! I tryed but it only got worse, So i went back to the original and now im in dire need of your help!! 🙂
    _Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/storage/5/0e/63/pesomorto/public_html/plugins/content/jaavtracklist/jaavtracklist.php on line 142
    Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/storage/5/0e/63/pesomorto/publichtml/plugins/content/jaavtracklist/jaavtracklist.php on line 142
    1. site_problem
    Pankaj Sharma Moderator
    #970403
    Kindly apply the fix given in this thread for the same topic .
    aluduarte Friend
    #970633
    You are THE MAN! Thnks a lot my friend! The solution worked perfectly!!
This topic contains 2 replies, has 2 voices, and was last updated by  aluduarte 8 years, 3 months ago.
