  • aceeis Friend
    #122904
    the columns in the template do not resize automatically and create an awkward effect on the page…see my site http://www.vaffantennis.it …any fix for that? I had a look at the Css but could not find an answer…
    Andrea
    lehoai Friend
    #230050
    Hi aceeis
    There is a few error on your site is the module mooticker in your site was include mootools and JA templates has include mootools too. So its will conflig. The second is your the module mooticker is has a javascript error. So to fix this bug you can try
    – one is you can disable the module mooticker.
    – two is you can hack the code in this module to disable include mootools in this module.
This topic contains 2 replies, has 2 voices, and was last updated by  lehoai 17 years, 3 months ago.
