brenot Friend
brenot
- March 2011
- 8 times in 3 posts
March 8, 2013 at 1:16 pm #185649Hi,
i´ve been started a new website running JA BRISK 1.0.2, J2.5, and I found a issue with the columns, like you can see at the image file, and through this link http://184.172.137.191/~harasmhc/_novo2/index.php/typography
Thanks for any help
Saguaros ModeratorSaguaros
March 11, 2013 at 10:19 am #486011Hi brenot,
This template doesn’t support RTL language so that it may have unwanted issues when using this template in RTl language.
brenot Friendbrenot
- March 2011
March 12, 2013 at 2:05 am #486090I dont set anything to RTL, i just installed the quickstart..I just talking about regular sidebar-2 module position
brenot Friendbrenot
- March 2011
March 12, 2013 at 2:08 am #486091How can i set to normal LTR ?
thanks
brenot Friendbrenot
- March 2011
March 12, 2013 at 2:02 pm #486196Repeating, I just install quickstart and the website is like that.. Can somebody help me to fix it, and configure to LTR ?
March 13, 2013 at 2:25 am #486247Hi brenot,
This is so strange since I installed quickstart package of this JA Brisk Joomla 2.5 but it still displays in LTR by default.
LTR or RTL defined in your default language folder, suppose that your default language is English, you can open file: /language/en-GB/en-GB.xml, and look at this line:
<rtl>1</rtl>
If you want to configure to LTR, this line should be:
<rtl>0</rtl>
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by Saguaros 11 years, 10 months ago.
Problem with columns
