  • DotCom Limitada Friend
    #189040
    Hi there,
    I just want to let you know that there are 3 instances were the CONCAT_WS function is incorrectly defined. There is a space before the “(” which causes error. Instead of “CONCAT_WS(“ you have “CONCAT_WS (“
    One instance in components/com_jak2filter/controllers/cron.php and
    two instances on modules/mod_jak2filter/helper.php
    Best regards
    HeR0 Friend
    #499379
    Dear Dotcommz,
    Thank you for reporting. I will forward this to our Dev Team to consider as an improvement in the future.
    Best regards
This topic contains 2 replies, has 2 voices, and was last updated by  HeR0 11 years, 4 months ago.
