April 7, 2012 at 8:10 pm #175889
Hi, i use ja puresite.
when i installed concact form extension (foxcontact, flexicontact), and integrated it into the main menu, then ja-bulletin module (ja-tabs position) appears automatically on my contact page. after i disappeared the ja-bulletin module, there are stille a thick line on that position (look at screenshot).
this problem i just have on my server, but not on localhost. and the problem is on every contact form, that i ve test.any one knows how i can solve this problem? thank you very much.
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
April 8, 2012 at 3:34 pm #447761Could you give me usename+password of your backend? I will check it.
khoand Friendkhoand
- February 2011
April 12, 2012 at 8:15 am #448201I viewed your website, and it doesn’t like your snapshot. There is a snapshot of your website on my chrome 17
April 12, 2012 at 8:17 am #448202jup, if you try to disappear ipad- and iphone news, then you will see my described problem
khoand Friendkhoand
- February 2011
April 12, 2012 at 8:31 am #448204Because ipad and iphone news are loaded by Ja tab module (its id is 125). So you must disable Ja tab module also.
April 12, 2012 at 8:34 am #448205now i disappeared that module, but in concact site you will se the thick line, you see?
khoand Friendkhoand
- February 2011
April 12, 2012 at 10:02 am #448209i done that, but it didnt works. any way problem is now solved. thankx!
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by cuchirice 12 years, 9 months ago.
