  • chomik Friend
    #999347
    I have problem with container-slideshow. When I create this container I see this:
    container_slideshow_problem
    I can’t add anything to slideshow.
    Vicky T Friend
    #999712
    Having same problem….
    Am i doing something wrong here?
    Arvind Chauhan Moderator
    #999744
    Hi guys,
    Thanks for report us the issue, we are fixing the issue, it should be done really soon.
    Regards.
    #999757
    Hi again,
    The issue has been fixed, please check again. We tested on our demo and it works properly.
    Rergards.
    zahidrasheed Friend
    #1001509
    start using the builder since 8th of January 17 but i’m having the same issue… cannot add slides if press ad block nothing comes up… how to add more slides?
    thanks
    #1002038
    Hi @zahidrasheed,
    Did you upgrade to alpha 2 version? If you did and you still get the issue, please provide us your site info, we will check and fix as we tested and it is working fine from our side. Please set the reply as private so only me can see the site info.
    Regards.
    pzosso Friend
    #1004885
    I set a slideshow with 2 slide but the transition are not working. I need to click to pass to the 2nd slide.
    #1004960
    Hi @pzosso,
    So you mean the auto display to move to new slide in a defined duration? Could you please provide a screenshot hilighting the issue to make sure we understand the issue correctly?
    Regards.
    pzosso Friend
    #1005172
    Correct in my situation the slide do not move automatically to the next one.
    http://www.thisan.ch
    1. slide
    #1005639
    Hi pzosso,
    Let me check with the development team if the content block support auto play or not, if not, I will suggest them to add an option to enable or disable the auto play.
    Thanks for your report.
    Regards.
    pzosso Friend
    #1020589
    Hi Arvind,
    Do you have any news about the auto play of the slides?
    Best regards
    Patrick
    Hi Patrick,
    The ‘autoplay’ feature is available now, pls check it out.
This topic contains 11 replies, has 6 voices, and was last updated by  Saguaros 7 years, 9 months ago.
