maroctravel Friend
maroctravel
- August 2011
August 10, 2011 at 10:51 am #167249Hello,
I installed Joomla en the Travel template using the quick install folder. I also purchased the copyright removal for 1 domain.
I am now following the steps in the PDF that was send to me but somehow the copyright sentences are not removed. Not sure what I am doing wrong here.
I opened the joomla_root/templates/ja_template_name/templateDetails.xml file and modified as followed:<name></name>
<creationDate></creationDate>
<author></author>
<authorEmail></authorEmail>
<authorUrl></authorUrl>
<copyright></copyright>
<license>GNU/GPL version 2</license>
<description></description>
<version></version>
<engine>t3</engine>Is this correct?
I was able to turn off the T3 ad banner on the right (profile -> no show)
Thanks for your help!
Petra
himangi Friendhimangi
- April 2011
- 345 times in 332 posts
August 10, 2011 at 11:38 am #405382Hi Petra
You need to put something in the name tag and check if it changes in the extensions > Template manager. As per my knowledge all these tags will show info in the joomla backend only.
1 user says Thank You to himangi for this useful post
maroctravel Friendmaroctravel
- August 2011
August 10, 2011 at 9:54 pm #405513I tried that, buty nothinhg seems to change.
So how should I remove the copyright sentences?
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
August 10, 2011 at 9:58 pm #405515Which sentences are we talking about here? The ones at the bottom of the page?
If you drop me a PM with both an admin login and an ftp account I will edit them for you. What would you like them to read?
- August 2011
August 11, 2011 at 8:25 am #405597Hello Phill,
I sent you a PM 🙂
Thanks!
- February 2014
August 11, 2011 at 8:31 am #405599Thanks, I will do this when I get home from work later today.
- February 2014
August 11, 2011 at 11:02 am #405624I have edited the footer for you as requested and sent you a PM detailing how it was done.
- August 2011
August 11, 2011 at 4:37 pm #405723Thanks so much for your help!
This topic contains 8 replies, has 3 voices, and was last updated by maroctravel 13 years, 4 months ago.
