  • Trần Mạnh Friend
    #920901
    Hi there,
    I’m trying to create a magazine layout. But it’s seem doesn’t work. Here is my setting.
    https://goo.gl/photos/vsTqCR5TJpXuxcPv5
    How can i make it like in demo!
    Thanks in advanced.
    Pankaj Sharma Moderator
    #921296
    In this case i suggest you to check the template documentation for Magazine Page Here .
    You can also install the Quickstart version on your site and then check all the Menu settings from the package .
    Apply the same on your site .
    Note : Kindly Post the thread on correct forum , This forum is for Purity template and your question is for Purity III .
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 7 months ago.
