October 9, 2014 at 6:58 am #201938
I’ve troubles with creating the footer-5 module position. In the current site you see the “Neem contact met ons op” module in footer-4. Also the SP Quick Contact Form is placed in footer-4.
Now I want to load the SP Quick Contact Form into footer-5.
When I want to add footer-5 into the Layout configuration it doesn’t save the footer position.
I hope somebody can help me with this issue. Thanks a lot.
Site is: http://www.novabridge.nl
October 9, 2014 at 8:13 am #552374Hi
Please take a full backup of your site . and update the Template and T3 plugin to latest version 2.3.2.Make sure when you update your template , it will override all the css and php files , so take a backup of all files .
Update T3 and check it again .October 9, 2014 at 12:25 pm #552391Dear Pankajsharma,
I’ve updated the template and plugin but still have the same problem. Do you have more solutions?
With kindly regards,
RonPankaj Sharma ModeratorPankaj Sharma
October 9, 2014 at 12:29 pm #552393Hi as i checked your site , i found this error >> Error
The template directory is not writable. Some features may not work.Please check your template directory permission , this is causing the issue .
October 9, 2014 at 1:33 pm #552398Sorry but I can’t find the solution 🙁
I find it… But now when I use footer-5 it doesn’t use the 100% width.. Do you have a solution for that?
October 9, 2014 at 2:32 pm #552417Hi Footer-5 position is using span2 .
so the image size is reduced according to the span size .
If you want to display it in a full width you need to change the span size of footer-5 position from
template manager>>ja medicare>>layout>>responsive layout >>>> http://prntscr.com/4ui7nvyou can change it like this >> http://prntscr.com/4ui7uk
But ,make sure after that it will comes under the footer 1234 positions -
This topic contains 6 replies, has 2 voices, and was last updated by Pankaj Sharma 10 years ago.
