  • filomena78 Friend
    #173459
    I’m using the template ja_nez, I changed some css in the t3-assets folder, but after a few minutes when I refresh the page are automatically self-generated new CSS so my changes are lost: how is it possible? :((
    Thanks,
    Filo
    You are using the cached folder your changes must be done in the templatecss folder
    What are you trying to change ? maybe i can help to identify the correct css file
    filomena78 Friend
    #436608
    thanks for your answer 🙂
    Now I’ve modified the file template.css in the folder templates/ja_nex/css (I think it’s the right file) but the changes are only visible on the homepage, if I change page back the previous settings.
    At example, I’ve changed the colors of the accordion module: here (http://www.csvcosenza.it/newsite/index.php) are green and blue as I want, but here (http://www.csvcosenza.it/newsite/index.php?option=com_content&view=article&id=1&Itemid=455) they return blue and black as default, while in this page they still remains (http://www.csvcosenza.it/newsite/index.php?option=com_content&view=article&id=68&Itemid=466).
    If you watch the same things happens with logo widht: why? :((
    Thanks,
    Filo
    You are using the blue theme so you must check your css in this folder too templatesja_nexthemesblue
    There are two folders css and images
    Also if you still need help could you set Optimize CSS to No from your template manager GLOBAL configuration tab ?
    So i can check better your css files
    filomena78 Friend
    #436615
    Thank you 🙂
    Now, setting Optimize CSS to No, I can see the right files with Firebug 🙂
    But I’m afraid that if I set again on Join&Minify the problem will happens again :((
    For the moment I leave it on No, than… I will see.
This topic contains 5 replies, has 2 voices, and was last updated by  filomena78 12 years, 11 months ago.
