  • acusticambiente Friend
    #188060
    when i update t3frameworks plugin or when i switch off development mode (after compiled less to css…) I lose all customizations of my site…
    TomC Moderator
    #495150
    This is because – depending on the CSS files you are modifying – when you update your T3 files, they are overwriting various files that you may have previously modified. Hence, the need for/power of layout overrides.
    SEE THE FOLLOWING RESOURCE LINKS . . . .
    How To Override Output From The Joomla Core
    Understanding Output Overrides
This topic contains 2 replies, has 2 voices, and was last updated by  TomC 11 years, 6 months ago.
