  • lawweaver Friend
    #125091
    I am using ja fagus. Fantastic. I just have a couple of slight problems.
    1/ Because this is a dark template with white writing this is coming through on many of my components making the text unreadable aginst the white background of the component. Try as I might I can’t find somewhere to adjust this in the css (I am totally new to this though so I’m probably just ignorant). Can I change something to make the font colour different on components or do I have to change it component by component? Also if I can could someone tell me where?:confused:
    2/ The footer copyright information for both ja and joomla seem to float up and down. I’ve noticed pariculaly in the ‘contact us’ page and in the sobi2 ‘ add review’ page when I add something and then press enter, the copyright info is over the top and I can’t actually activate whatever I’m trying to click. Is there some way to stick this info to the bottom of the page, or actually delete it?
    My site is at http://www.puremusic24.com
    Many thanks Nick:)
    kashxo Friend
    #236808
    Which and where did you found that your text is hard to read? Could you point me to the right location?
This topic contains 2 replies, has 2 voices, and was last updated by  kashxo 16 years, 12 months ago.
