Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
May 8, 2015 at 3:54 pm #206201I am unable to find a solution to align the “Quick Info” block. So that it is not right and the left margin, as shown in the attachment.
Tag: <div class = “pn-fast-info”>
I have little practice with Bootstrap
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
May 8, 2015 at 7:25 pm #569974Not entirely certain how, exactly, you’re wanting to align things from your description above.
Can you be a bit more specific?
Tech-xml FriendTech-xml
- October 2010
May 8, 2015 at 8:37 pm #569983Thank you for answering @tomc
Annexes:
The first marked with red vertical stripes shows where misaligned
The second shows how it should look after correction.-
Tech-xml Friend
Tech-xml
- October 2010
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by TomC 9 years, 5 months ago.
